If you can post on here and send emails with attatchments then putting pics up is a piece of pish.
1. Go to
www.photobucket.com and register.
2. Once in your gallery there is a "Choose" button, click it and it will open a window to allow you to browse your HD for the pic you require. You can also select to choose multiples if you have more than one pic to put up at a time.
3. When you have selected it, click "Upload" and after a short pause the pic will have transferred from your computer to PB's server and will appear in your gallery.
4. Under the pic will be three boxes of text. Right click the text in the bottom one labelled "Img" and copy it.
5. On a post in here, right click and paste the text and it will appear with all the necessary syntax to allow the pic to show.
6. Submit the post.
