okay so i have done some work on the list and added some extra stuff. Like i said there are too many ecu's to cover everyone's needs so i will be focusing on earlier impreza's
U8, 2C - 1993/1994 WRX – TDO5-11.47PSI (0.8BAR) TO REDLINE -FUELCUT 14.5PSI (1BAR) - 240PS (237BHP)
W6 - 1993 WRX RA – TDO5- 11.47PSI (0.8BAR) -FUELCUT 14.5PSI (1BAR) - 240PS (237BHP)
W9 - 1994 WRX RA - 11.47PSI (0.8BAR) -FUELCUT 14.5PSI (1BAR) - 240PS (237BHP)
SA (STI CHIPPED) - VER1 STI (SEDAN AND WAGON)- 14.94PSI
SB (STI CHIPPED) - VER1 STI-RA - 13.64PSI
SC (STI CHIPPED) – SAME AS Z4 - VER2 STI WAGON - -12.7PSI (0.9BAR), DROPPING TO 11.7PSI (0.8BAR) @ 6600RPM
FUEL CUT 15.65PSI (1.08BAR)-260PS (256BHP) - 7250RPM
Z4 - 1995/1996 WRX – SAME AS SC- 12.7PSI (0.9BAR), DROPPING TO 11.7PSI (0.8BAR) @ 6600RPM
- FUEL CUT 15.65PSI (1.08BAR) - 260PS (256 BHP) – 7250RPM
Z5 - 1995/1996 WRX-RA - 12.57PSI
6K - VER2 STI SEDAN – SAME AS PRODRIVE-TDO5- 13.33PSI (0.92BAR) BUT PEAKS TO 13.6PSI (0.94BAR) @ 5600RPM, THEN DROPS TO 12.71PSI (0.87BAR) @ 6600RPM- FUEL CUT 15.65PSI (1.07BAR)-7500RPM-380CC
7K - VER2 STI-RA - 13.17PSI(0.9BAR) BUT PEAKS TO 13.64PSI (0.94BAR) @ 5800RPM- FUEL CUT 15.96PSI (1.1BAR)-
PRODRIVE UK ECU (PRODRIVE CHIPPED) – SAME AS 6K – 13.33PSI (0.92BAR) BUT PEAKS TO 13.6PSI (0.94BAR) @ 5600RPM, THEN DROPS TO 12.71PSI (0.87BAR) @ 6600RPM- FUEL CUT 15.65PSI (1.07BAR)-7500RPM-380CC
1C, 3B, V9, V5 , V9, 4B, ALL(?TBC) WRX WAGONS - 10.55PSI (0.7BAR) DROPPING TO 6.84PSI (0.5BAR) STARTS TO DROP @ 5000RPM – FUEL CUT 13.79PSI (0.95BAR) -
V7, 7D, 6D - 1993 TO 1996 UK/EURO - 11.4PSI (0.8BAR), DROPPING TO 9.4PSI (0.65BAR) @ 6600RPM – BOOST CUT 14.87PSI (1BAR)-
