Simtek does not have "adaptive" control over fuel and ignition functions in common with most aftermarket ECUs.
The knock control (due for release on MY00 onwards Jan 1st and other models Feb 1st) will pull ignition across user defined zones depending on knock severity and there will be options regarding the "recovery strategy"; however this will not be a "learning" mode as per OEM ECU.
Currently sensors can be read by purchasing the Customer Software kit which would enable fault diagnosis, but for the future we are working on the possibility of using the tacho to display a value relating to an out of range sensor value.
Steve
