Thought I had a thread for her already though can't find it so must assume that i don't . I've had her for nearly 18 months now and thought I would post some updated pics and list work done so far. Here she comes.....
Is this my best side?
Does my bum look big in this?
Anybody name which OEM stereo this is?
M-Tech engineering gear ****.
List of work done so far is as follows:-
*AEM induction kit.
*ProDrive de-cat and centre pipes.
*Custom backbox from Infinity Exhausts (Bath).
*ECU re-map by Duncan (AKA Race Dynamix) to 340 / 340.
*M2 strut tower bar installed.
*Personalised registration plate.
*Widetrack alloys re-coloured black.
*Front trim re-coloured black (Fog light surrounds, headlight eyebrows and grill trim)
*ZunSport black grill set.
*HT Autos lowline kit.
*Hella Supertone horn kit fitted.
*Rally Armour mudflaps fitted.
*STi winglets replaced with JDM black versions.
*Perrin wing riser kkit fitted.
*Mirror-Matic upgrade fitted.
*Rear lights re-cooloured red.
*Rear parking camera installed.
*Exhaust surrounds re-coloured black.
*JDM rear fog light cluster installed. All rear clusters tinted.
*Perrin radiator shroud installed.
*RallyTech engine bolt kit installed.
*AVT intercooler cover installed.
*OEM head unit installed (Not sure which Subaru its from?)
*M-Tech Engineering gear **** installed.
Future plans:-
*All the silver internal trim refurbished.
*Wider wheels or spacers.
*Engine to be forged.
*FMIC.
*New turbo.
Thanks for reading guys!
8ulldog
Great looking car you have there. nice list on the future plans. by the way, what paint did you use for the exhaust?
Thanks. After a good clean and light sand I used E-Tech self etching primer (2 coats), E-Tech black alloy wheel paint (3 coats) and E-Tech lacquer (3 coats). Looks a lot better IMO and that's nearly all the chrome gone!
I tidied the engine bay up a little today after fitting my Perrin radiator shroud, RallyTech bolt kit (Really disappointed as loads missing) and intercooler cover. Well worth the effort!
Was it you that was looking for instructions to fit the bolt kit ? Did you see the pic i put up ?
You missed the bonnet struts and the wing fixings.
I used the leftovers to do under the bootlid too , tail lights , gas struts , spoiler.
Yes. I used your pictures for reference, thanks, as Rallytech never bothered replying to my emails. I have none of the medium / large bolts left and so there are loads missing, though I have loads of the small ones left which I will finish off later. I bought the kit from a guy on here so I'm not sure if the issue is with Rallytech or him.
Also one of the battery stays us nearly double the length of the original.
Think the kit it very generic , i had a set on my bugeye and had the same issue. You seem to have too many of some and not enough of others. Like i had enough short ones to do boot but no big ones for my Intercooler (which i would've like to change).
I bought a newage STI battery clamp off a breaker and told him i didn't need the fixing rods. Luckily he sent them anyway as my standard ones were too short.
