Thoughts on this type-r
What do you think of this? I can get it for 10k. Always fancied a classic. Its silver, looks very clean. Not sure about the front bumper though.
This is the spec:
V4 STI Type R
64,000 miles.
Imported 2001
Full Uk history, receipts folder.
2 owners since 2004 most of which time garaged.
All work carried out to a high standard.
Great car in and out.
Engine:
EJ257
Mahle Forged Pistons
Rebuilt V3 STi heads
RCM K&N induction Kit
ARP 11mm Head studs
1.4mm Subaru Headgaskets
Water Pump
API Modified Oil Pump
Zen performance Repainted Inlet Manifold
Gates Timing belt and tensioner replaced
Rebuilt AFP 20g
550cc Injectors
Samco Inlet Pipe
ZeroSports Aluminium induction pipe
ECU/management
Apexi PFC with hand commander (Installed and mapped by Paul at Zen)
AVCR (Installed and mapped by Paul at Zen)
Cooling:
ZeroSports Cool Thermostat
Brand new Radiator just fitted
Hybrid FMIC
Custom air intake from front bumper
Samco Radiator Hoses
Exhaust:
Ceramic Coated Equal Length Manifold
Ceramic Coated Up-pipe
Kakimoto GT 1.0z Titanium Exhaust (extremely light and loud)
Fuelling:
550cc Injectors
Fuel lab FPR
Walbro Fuel Pump
Brakes:
Godspeed front big brake conversion with Blue Stuff pads (5K Miles)
Godspeed Rebuilt front callipers
Grooved Disks all round
Blue stuff rear pads (5k miles)
Rear Handbrake Shoes replaced (2k miles)
Brake Stopper
Braided Hoses all around
Drivetrain:
Helix 230mm Extra uprated Organic Clutch (12k)
5.4KGs Lightweight Billet Flywheel
RCM Blue Lightweight Pulleys
DCCD Gearbox
This is the spec:
V4 STI Type R
64,000 miles.
Imported 2001
Engine:
EJ257
ARP 11mm Head studs
Water Pump
Rebuilt AFP 20g
550cc Injectors
Samco Inlet Pipe
ECU/management
Cooling:
Hybrid FMIC
Exhaust:
Fuelling:
550cc Injectors
Fuel lab FPR
Walbro Fuel Pump
Brakes:
Brake Stopper
Drivetrain:
DCCD Gearbox
front bumper is easy swap, looks wrong colour too. I'd be questioning why it is not standard and having a good look in behind it.
these tend to rot at the bottom of the rear arches by the side skirts and up inside by the rear turrets, its impossible to see the rear turret rot unless you remove the side covers from inside the boot and use a camera to take a pic
personally i'd take the front brakes off as the pads dont sit well in the calipers and dont wear evenly, and replace them with a set of brembo's
5 or 6 speed box? DCCD is awesome, if you havent driven a car with it then take it a bit steady on the roads, the 5 speed DCCD is less forgiving than the 6 speed but still a great setup
2 doors are where the money is at, and always will be, could be a good investment
hope this helps you make up your mind
defiantly have a good poke round, around rear arches, inside boot near the turrets, i looked at an impreza a few months back that looked very clean, but found holes on rear turrets, and inside rear arches!!!!
