Stripped cambelt tensioner bracket bolt hole!
Honestly wtf. Are these things made from cheese? Had the torque wrench set to 25nm and it never clicked. Just carried on turning until I thought "what's going on" and took the bolt back out. Found half the threads on it.
FML.
FML.
I've jusr helicoiled mine after the thread stripped removing the sump baffle. Lots of packing and checking to make sure not swarfe was left in the block...
I know, it's the hole the bracket itself bolts to. Well happy after already having to helicoil one of the oil pump bolts! I feel like I'm constantly having to unbodge other peoples' **** ups and today I've had enough.
Going on Amazon now to buy an M10x1.25 helicoil kit.
I've had real fun with this... The first helicoil wasn't in far enough so I ended up damaging the bolt. I managed to remove it and get one in properly. Bolt is in and torqued up for test purposes but I want to replace it as the body of the bolt where the threaded part is goes noticeably narrower where it was partially cross threaded into the dodgy helicoil.
It torques up but being narrower I can't trust it now. Unfortunately I cannot find a replacement bolt on its own..... I am considering using a normal high tensile M10x1.25 bolt with a small washer behind it but I'm not sure if there will be any problem doing that?
If it's the long bolt (item 10) it's the same as used through the small idler.................
For example
https://www.importcarparts.co.uk/par...y=&searchPart=
If it's the shorter bolt (item 12) it shouldn't be too difficult to get one
For example
Yes but when I went to screw the bolt in it cross threaded slightly the first time because the helicoil wasn't far enough in and I couldn't actually tell until it was too late. When I took the bolt back out it had sort of smoothed down the very edges of the threads. It still screws in and torques up, so most likely not damaged enough to be an issue but I'm worrying about it all the same.
I wouldn't worry, I've helicoiled 2 threads for my sump baffle - the blocks are made of margarine (I mean aluminium) and the helicoil inserts are steel which is stronger and tougher so if it's torqued up it will be fine...
I'm now a little confused as you said the hole that had stripped was in the bracket that the tensioner bolted to.
The Tensioner is the complete item ringed in red below and it looks as if the tensioner idler has been removed due to the chewed up bolt head (marked 1)
The tensioner bracket is the item bolted to the block using screws marked 2 & 3
If the bolt that has been stripped/helicoiled is bolt 1 and you are not sure about it then get a new tensioner.
