Centre diff bearing question - 93 WRX
As per title - it looks like I'm going to have to attempt to change the centre diff bearings in my 1993 WRX myself (TY752VB3AA gearbox, if that makes any difference).
Most guides feature the diff on the right, and give bearings to suit:
However I'm pretty sure I have the diff on the left (as my car is pre-98).
Are the bearings the same for both diffs? I can't find any information either way.
Thanks in advance!
Thanks in advance!
Here are some of the bearing part numbers for a Rev B (1993/05-1994/09) WRX
Part numbers listed are superceded items so.......
Part code G44102 in the list refers to item G44101 on drawing
Part code G42008 in the list refers to item G42006 on drawing
Part code G23015 in the list refers to item G23012 on drawing
Those listed here for an early UK box are similar
http://opposedforces.com/parts/impre...llustration_2/
Ok, this is really stressing me out so would really appreciate some further help!
On the above diagram, number 10 (aka G23012/G23015/806230150) looks like this (which appears to be the correct item for a Phase 2 transfer case):
However the part number corresponds to this:
What looks like the same bearing but without the tabs.
I'm looking to order a replacement along with a second hand centre diff unit - does anyone know which bearing I should order?
..Or should I just buy the second hand diff, bang it in, and hope the straight-cut-gears-sounding whine goes away before ordering individual bearings?!
