Classic RA Roof Vent
Thinking of sorting out a classic ra roof vent so need to replace a few bits on it. Easy job lol yeah right it seems ICP only have certain bits and can't find the part numbers.
The bits needed are internal trim screws, most of the screws and the bit that connects the roof flap to the handle. Had a look on opposed forces but seems to only show European cars
Any assistance is much appreciated
Not an essential part but the sticker on the inside was thinking of painting it again.
Had a look on there a while back and couldn't find anything, looks like I was typing the wrong thing in.
So close thought I had it then lol
The bit in the picture is what I need but can't seem to find any part numbers
Does any body know
Does any body know
Had a call from Subaru parts UK and they only sell with the vent so its £329 just to buy that nut
Someone on here must know if there is a different part number or what else could be used
Part needed
Part needed
The boss (which you circled above ) to which the roof vent lock (65448FA000)
screws to the roof vent is only available with the vent (along with the screw).
All other parts can be found separately.
Parts diagrams and part numbers re-established
Classic version
Newage
Classic version
Newage
Thanks Don much appreciated
I was really hoping you weren't going to say that lol. When you say boss is it the rivet type that the screw then attaches the handle to. Any idea of alternatives or if the Spec C ones are sold and will fit.
Items
65288
65268
65475
733B8
Q680001
Thanks again guys
Items
65288
65268
65475
733B8
Q680001
Thanks again guys
Thanks Don
I assume you work at Subaru Parts UK
Given the part numbers to Subaru so it should be easier to locate them. Will let you know if they find the parts
Have just done a search on some of the part numbers and it looks like they are used on a 1988 Justy for the opening rear side window catch and hinges.............
I did a quick search and I found they were from a different model earlier on
Its unlikely they they would have two different things with the exact same part number
Loads of models share the same screws etc so lets see if it fits. This is from a Spec C going into a classic RA vent thats a whole different thing lol. If it does work out then saves others from buying a complete lid.
