New terzo, bad lights
Hi People. Just got a Terzo but don't like the lights, any idea what these ones are and does anyone want the lights?
They're Morettes:
http://www.morette.com/products/HEAD...EZACLASSIC.htm
I have some crystal facelift lights like this, located in Cambridge, if you fancy them?:
Those are the Morette conversion. They went for £325 un-painted in the day.
They are MILES better than the stock lights, having Cibie (or later, Hella) light units in them, which actually focused the light rather than scattering it like the stock lights do.
Having an outer, larger, pair doing dip and main beam off an H4 bulb, and a smaller inner pair doing extra main beam with an H2 bulb, they put a LOT of light out.
If the light units are good, keep'em. If not, find replacements off ebay, Hella do some now.
If you don't want to be seriously disappointed, DO NOT go back to stock lights. You have been warned
What other mods? Bigger injectors etc...
Remapped?
You might be running rich on cruise/idle and lean on WOT??
I would be worried about a fuel smell , check engine bay pipes first see if it’s damp , then follow lines back to the tank , sulphur from cats is normal a fuel smell not good , but if its just a split pipe easily solved
I had the fuel smell.
One day it got eye watering as I came back from the supermarket, and fumes came out of the bonnet as I turned into our drive. I popped the bonnet and was appalled to see fuel p*ssing out of the pipes that run across the bulkhead, all over the hot exhaust, turbo etc. There was a split an inch long!
I switched off and waited for the "WHOOMF" as it went up, but it didn't.
Pipes now replaced with the correct stuff, which wasn't cheap, plus new stainless clips. I think the designation is B9, but Ali B on here knows.
All very helpful, thanks. Will check the lines this afternoon. I have only had the car a week and got it from a guy who had only had it for a short while (I think a matter of weeks from the log book). I don't have much history with it (mot's an engine rebuild and a dump valve ) so annoyingly don't know what's been done mod wise ( apart from front intercooler and air filter + zorst ). I guess I need to check the de cat situation out. Fuel smell isn't huge but is there! Also it has a crap aftermarket radio, what did they have from the factory?
Radios are not often that good but upgrade path is easy , halfords do double dins with bluetooth for around 105£ depending if yours is double or single din , there is a known starting issue it’s down to a pipe i don’t know details as i have never had the issue , i’m sure the web will tell you , but well worth checking all the pipes
My old terzo suffered fuel filler pipe corrosion to the point of pi55ing out when I filled up,worth a check,also the pipes that lead to the fuel breather canister can come off so also worth a check(drivers side front headlight,if you look under you will see the black pipes going into the canister,they run close to the fmic pipes)
My guess is still rich running tho
