How does the mishimoto perform ? I like the look of the Perrin and cosworth one aswell though. Much difference over the standard air box other than sound ?
No idea yet sorry lol
I bought and fitted it when I had just taken my car off the road for the winter. Looks well made. Shame you weren't looking in November as Mishimoto had 25% off there entire catalogue. Made me spend a fortune as I now have a twin catch can setup and uprated tmic because of it lol
mk3 Focus RS "panel" filters are a perfect fit for them (or any aftermarket intake pipe) - i run a Ramair item on mine
Ramair filter
Ramair filter
Have you looked at upgrading the main beam bulbs?? lots of options out there with upto 120% more light
The other alternate would be LED light bars either in or behind the lower grille area.
The Lazer Lamps lights are fantastic but rather expensive, but there are others out there
Notice the blue tinge showing in the main beams - uprated bulbs as well
Running a Perrin CAI in conjunction with an FMIC and still managed to get the large filter it comes with to fit.
Both the Perrin and Mishi have MAF airflow straighteners which are pretty good. The Mishi is the most cost effective. They were out of stock when I ordered mine.
Under seat subwoofer
So a fellow hatch owner has discovered a sub under his passenger seat. When I first got mine I looked into buying one but seemed to be an American thing and quite expensive so gave up.
His looks pretty "oem" And I'm wondering how easily they're wired up ? Plug and play ? At most maybe have to feed a wiring loom up to the head unit. I have the touchscreen nav unit , and it has a sub control in the settings.
any info appreciated.
https://m.ebay.co.uk/itm/183003605871
seems OEM, looks like the one in the link.
Installation instructions can be downloaded here............
https://techinfo.subaru.com/stis/doc...G000139124.pdf
I’m having my fuse box dipped on my hatch and was wondering whether I can cover it for 3 or 4 days with a plastic bag ? Or if anyone else can come up with a better alternative ?. I’m worried about the heat melting it.
IGNORE ABOVE WRITING JUST USED DONS PIC OF HIS AOS
Just fitting my aos see the three hoses in red they are tee’d together as i dont have bar can i just tee the yellow one (pcv) like in this pic cheers
