The instructions were hopeless but I figured it out 🙈
The emblems I’m not sure how much they were not a lot although the most expensive item on the invoice at 6200¥ , I think that’s about £40
Nice. Has the master cylinder brace made any noticeable difference?
£40 is what I paid as well from https://www.ebay.co.uk/itm/GENUINE-S...wAAOSwLVZV5XeY
Gear and diff oil change
hi I’m wonder if anyone on here can help ,, I want to do the diff and gear oil in the scoob , I’ve got all the fluids that’s fine , motul gear 300 and 300 ls courtesy of opie 👍🏼
but I can’t seem to find out the size of or get hold the drain and inspection hole gaskets / washers anywhere apart from icp and their prices are mental £5 for the gear sump bolt washer ,, I think the gearbox drain hole is an m26 ? Can anyone shed some light on this for me ?
Thanks alex
Thanks alex
https://www.scoobynet.com/drivetrain...rbox-oils.html
Why 300LS ?? when subaru recommend straight GL-5 oil for gearbox and both front/rear diffs ?
The headgasket went last month, so I have dropped the scooby off at thwaites developments racing in Warwick last week for a forged rebuild, cobra decat downpipe, cosworth panel filter and rcm fuel pump and, once run in, a remap. Place predictions on power outcome please! It already has a 3" cobra system in place, so will be 3" all the way through.
I would say maybe a lil more 360ish would be ok , interesting how your going uprated fuel pump , I’m still running the standard one at 415 hp / 415 Lbft I personally would go injectors over fuel pump just future proof the car a lil incase you fancy a bigger turbo at some point
The reason for fitting a new/better fuel pump esp with an increase in power is because the OE one has probably been on the car for a while and are also prone to failure. OE pump is also probably a weaker piece of kit.
You won’t notice the slight failure but can lead to delivering less fuel, car runs lean. Potential to go bang
Fit a fuel pump!
Fit a fuel pump!
It was something Mark at tdr and Olly at rcm both said to replace, they suggested that the oem pump after 70k miles is now no longer likely to be performing as well as it was when new. 340 would be good, 360 would be fantastic!
great day out in the Subaru , got to do some drag racing and meet tiff from fifth gear
this S1 I'm racing was second fastest on the day and was very quick and surprised a lot of people
it’s a slippery slope tho mate once you get the bug you’ll just want more and more haha
https://www.youtube.com/watch?v=4v8mwPcKK_Y
Anymore detail? as the SRT202 recall other people seem to be banding about was checked on mine in November 2015
ive had all the secondary air pump and egr removed haha so that one doesn’t bother me as much , but the brakes do no doubt they will probably Pretend they don’t know what I’m talking about..... what are the parts that leak ?
I went to fit the Whiteline rear subframe bush inserts today on my 09 spec C, but they didn't slot straight in, so the spec C appears to have different subframe bushes from the standard hatch. I also have a spare set of Whiteline diff inserts, as mine was already done, if anyone is interested
The hatch STI (inc Spec C) rear subframe was in continual development on the Rev A and Rev B models having 8 different part numbers between 03/2007 when production began and 06/2009 when production finished.
